I have been playing with the search option of XnView 1.96 a bit.
I noticed a bug when I select 2 criteria at once.
When selecting more then 1 item I presume these criteria
must both be met ("AND" function) in the listed result
However when I select the camera model EXIF info (In my case "A100") I find 44 matches in a certain dir.
If I also select the fileformat (eg. DCM - Dicom) then I still get 44 matches, however I don't have 1 single
image of type DCM anywere
If I select only DCM type m then XnView confirmes this by finding no matches.
I haven't tried any other combinations, but this one I buggy I believe.
René
Search with several criterias does not work properly
rra
marsh
Re: search
Same result here using 'width greater than 1024' AND Exif search (all fields for "20D"). Only Exif search was used. Same combination worked as expected with IPTC search.rra wrote: I haven't tried any other combinations, but this one I buggy I believe.
