gflBitmapSetIPTC - in which DLL?
kurka666
Post by kurka666 »
I tried to use the gflBitmapSetIPTC function (from Delphi) but when I add it into the LibGfl unit like I have done for other missing IPTC-functions, I get the error "The procedure entry point gflBitmapSetIPTC could not be located in the dll libgfl220.dll". I have also tried to point to "libgfle220.dll" but with the same result
Re: gflBitmapSetIPTC - in which DLL?
kurka666 wrote:I tried to use the gflBitmapSetIPTC function (from Delphi) but when I add it into the LibGfl unit like I have done for other missing IPTC-functions, I get the error "The procedure entry point gflBitmapSetIPTC could not be located in the dll libgfl220.dll". I have also tried to point to "libgfle220.dll" but with the same result
Strange, gflSetIPTCValue is in libgfl.dll
Post by Guest »
xnview wrote: Strange, gflSetIPTCValue is in libgfl.dll
Yes, very strange. Is it working with other languages than Delphi?
Ithier
gflBitmapSetIPTC
Post by Ithier »
I have tried in C++ and I cannot link my program, so I have searched all the GflSdk directory for the gflBitmapSetIPTC string and I have found it in only three places: libgfl.h, Whatsnew.txt and Help.chm.
So the function is realy missing.
Is it possible to have a corrected version ?
Thanks in advance.
Ithier wrote:I have tried in C++ and I cannot link my program, so I have searched all the GflSdk directory for the gflBitmapSetIPTC string and I have found it in only three places: libgfl.h, Whatsnew.txt and Help.chm.
I'll update soon GFL SDK, so please wait one week.
