Hi
Would you tell how to use and-function ("With all of the words"-option in Search-window) when searching from different IPTC-fields? For example, when I try to find images with word "Lisa" in description-field and word "car" in keyword-field. This seems to work only when both words are in same field.
searching IPTC words
Re: searching IPTC words
Yes, currently you can't make a 'OR'jpt65 wrote:For example, when I try to find images with word "Lisa" in description-field and word "car" in keyword-field. This seems to work only when both words are in same field.
rra
Pierre,
can you tell us what it can do it this moment,
can search use "AND" (or "OR") options and can these be applied between different fields (IPTC,format,size,...) ?
For now, I seem to get inconclusive results when doing some experiments.
If search-option can't do AND and OR at this moment, is this planned for the future ?
René
René
