I'd like to have an extension displayed separately, so I suggest to add these items to fullscreen and slide show "Show Infomation", if possible:
- <Extension> (e.g. jpg, png, tif)
...or/and
- <FormatShort> (e.g. JPEG, PNG, TIFF)
"Full" format is too long and it doesn't look good.
Thanks.
Fullscreen Information - display extension/format separately
Re: Fullscreen Information - display extension/format separately
+1 Support
I think the <Extension> would be better. From "Extension" users probably know right away what it does while "Format Short" is try and see.
Thanks for your support.
BTW there are more such "try and see" items, e.g. "<Filename Number>".
Why not both? Perhaps "JPEG" looks better than "jpg". Anyway, users should be able to choose.ckv wrote:I think the <Extension> would be better. From "Extension" users probably know right away what it does while "Format Short" is try and see.
Dreamer
