Overwrite All on Move?
Mike Truly
Post by Mike Truly »
I just tried to do a 'Move to Folder' on a large number of selected images. The folder destination already had the files with same names there so it popped up the dialog to replace... but I didn't see a setting for automatically overwriting ALL the files there. Is there a setting somewhere that will allow overwriting all?
Thanks!
Sincerely,
Mike Truly
Truly Media
http://www.trulymedia.com
Re: Overwrite All on Move?
Not yet, i must add it
Mike Truly
Just requesting this be added to the wishlist again.
When I use the Copy to Folder function and the image files are already in that folder, it pops up the 'Replace' dialog (which is fine) but there is no option to 'Replace All' so the user must continually click to replace each image. This is a productivity killer. A 'Replace All' button would solve this.
Thanks!
Sincerely,
Mike Truly
Truly Media
