Here is the file-example:
http://uploading.com/files/0MJYBX5F/gsd ... 6.rar.html
http://rapidshare.com/files/212963110/g ... 6.rar.html
Any other viewers shows it fine.
Incorrect BMP showing
marsh
Re: Incorrect BMP showing
Look at extra image settings:
<right + click + mouse> on image preview: [ ]Use alpha channel
(that should make display look the same as some web browsers)
- Forum Librarian
It's a 32-bit, semi-transparent image.
- Tools » Options... » View » View » Use checkerboard pattern as background
» Transparent areas allow the texture to shine through.
- Tools » Options... » General » Operations » Ignore alpha channel
» Transparency won't be displayed.
- Image » Remove alpha channel
» Transparency is deleted.
Kein
Hm... doesn't work for me.XnTriq wrote:It's a 32-bit, semi-transparent image.
Your image has a bad alpha channel, disable 'view/use alpha channel'Kein wrote:Hm... doesn't work for me.XnTriq wrote:It's a 32-bit, semi-transparent image.
