panasonic raw format?
BabaG
Post by BabaG »
what is the raw format and file extension for panasonic cameras (i'm primarily
thinking of the g1, right now) and does nconvert handle them?
thanks,
BabaG
Re: panasonic raw format?
Is it .srf?
BabaG
Post by BabaG »
i don't know. was hoping you did. ;) would hate to buy one of these things
and find nconvert couldn't work with it.
thanks,
BabaG
Panasonic UK & Ireland (LUMIX Digital Cameras » G Micro System » [url=http://www.panasonic.co.uk/html/en_GB/1564791/index.html]DMC-G1[/url] » LUMIX RAW Codec software download) wrote:Plug-in software that enables the display of LUMIX RAW image files (which have the extention of .RW2) when installed in Windows Vista® for Windows Explorer or Windows Photo Gallery in the same way as JPEG files.
PhotographyBLOG (Panasonic Lumix DMC-G1 Review » [url=http://www.photographyblog.com/reviews_panasonic_lumix_dmc_g1_3.php]Sample Images[/url] » Sample RAW Images) wrote:The Panasonic Lumix DMC-G1 enables users to capture RAW and JPEG format files. We've provided some Panasonic RAW (RW2) samples for you to download (thumbnail images shown below are not 100% representative).
BabaG
Post by BabaG »
thanks XnTriq. don't see rw2 in the list. any chance it might be added soon?
thanks again,
BabaG
BabaG
Post by BabaG »
oops. thanks!
