Same aspect ratio after a lossless crop
Dreamer
Post by Dreamer »
I'm not sure if this is a bug or a feature, but it's quite annoying...
When I use a lossless crop with a predefined aspect ratio, 4:3 / 1.33 for example, make a selection, 1600x1200, use a lossless crop, the new image size is 1601x1202, it's not always the same, but the aspect ratio is not exactly 4:3 / 1.33 anymore, even if "1.33" is in the status bar (a :bug: ?). It's just a small difference, but it's visible when viewing images in fullscreen.
Another strange bahavior. After a lossless rotate such an image (with the resolution 1601x1202 - 4 times), the resolution is changed to 1600x1200 and the aspect ratio is good (4:3 / 1.33). It's also a workaround to achieve the same aspect ratio after a lossless crop.
Dreamer
