nconvert for zenphoto
froggy
Post by froggy »
Thanks a lot for this wonderful tool.
I'm trying to make a batch to genereate zenphoto thumbnail cache.
it's ok for the resize and crop, but i did'nt find how to write the folder name "in" the filename.
for exemple, i should have this filename :
Is it possible to do this specific filename with the -o option ?
thanks in advance for your answer
Re: nconvert for zenphoto
Do you have tried to use $ (as folder name)?
marsh
Post by marsh »
xnview wrote:Do you have tried to use $ (as folder name)?
Problem with linux version? $ uses 'full path+folder', not 'current folder' for name?
froggy
Post by froggy »
yes, when i put a $ in the filename, nconvert append the whole path of the source folder ( instead of the file parent folder name only )
i use windows version
froggy wrote:yes, when i put a $ in the filename, nconvert append the whole path of the source folder ( instead of the file parent folder name only )
Right :-( so i need to add it
froggy
Post by froggy »
xnview wrote:Right :-( so i need to add it
i think that could be very usefull !
