Quicksnap & quickpaste
Kein
Post by Kein »
Err... does search are borken? No results for any of my requests (many variations) >_>
Anyway, here is the question: How I can adjust XnView so when I start it, it did a picture of the screen and inserted it into the window?
I tried to do it with standart windows hotkeys and "-capture=window/desktop" & "clipaste" flags - but it doesn't want to work.
Re: Quicksnap & quickpaste
Kein wrote:Err... does search are borken? No results for any of my requests (many variations) >_>
Kein wrote:Anyway, here is the question: How I can adjust XnView so when I start it, it did a picture of the screen and inserted it into the window?
Kein
Post by Kein »
Oh... As can I see there is no solution without runing XnView form the begining. Sadly ;(
Thanks anyway and sorry for the replica-thread >_>
Dreamer
Post by Dreamer »
I'm not sure what exactly do you need, but if you change option 'Save' in Capture dialog to "Open in XnView", then - if you start XnView with the parameter -capture=desktop, desktop screenshot will be created and opened in XnView - is this what you want?
Dreamer
Kein
Post by Kein »
0_________o
Yes, it is.
Actually, I barely can see any clues which help to understand that "Capture options" apllied for command line parameters as well but... meh.
Anyway, thanks, it just works like I want :P
