Convert Multi Page Tiff inside XNVIEW
nh2user
Post by nh2user »
Hello all,
I know this is possible using NCONVERt with the command line.
BUT what I would like is an option inside xnview for the -xall switch which splits all images inside the tiff (otherwise only first page is converted).
Is it possible to convert custom .bat files to .xps files ? or is it possible to customize the xnview command to nconvert ?
thanks for any info on this.
Re: Convert Multi Page Tiff inside XNVIEW
yes, right currently batch convert in xnview does not have 'xall' option...
But why you don't use nconvert?
nh2user
Post by nh2user »
Because I like to use a GUI. NCONVERT can't be used easily in windows explorer
nh2user
Post by nh2user »
xnview wrote:yes, right currently batch convert in xnview does not have 'xall' option...
Can you please please include a nice GUI for nconvert ? with xall option ?
your software is the BEST. Very fast and nice.
JPEG 2000 viewing is not as fast as acdsee, but it's the second fastest viewer for jpg2000
nh2user wrote:Can you please please include a nice GUI for nconvert ? with xall option ?
There is already a GUI for NConvert, but as of v1.20 it doesn't support the -xall parameter (yet).
