NEF too dark?
obelisk
NEF too dark?
when I shoot indoors on my D80, the camera shows a fine pic. When I move the NEF to Xnview, it shows up much darker. Is there an issue with how XnV shows raws?
I see the same thing with Pentax raws, but not such a big drop.
Re: NEF too dark?
Do you have tried to change settings for RAW?
obelisk
Re: NEF too dark?
what kind of settings are there?
Re: NEF too dark?
Option/Read-write/Read/RAW
obelisk
Re: NEF too dark?
I guess you mean camera RAW not RAW
What does auto brightness do?
I don't know how to set the gamma etc bottom 4 boxes
I tried crazy stuff like brightness 0.1 and it makes no diff to the view..
Re: NEF too dark?
Try 'auto balance' or 'camera balance' or 'auto brightness'
obelisk
Re: NEF too dark?
The Option/Read-write/Read/camera RAW
settings seem to have no effect on NEF and PEF files I have...
Re: NEF too dark?
Could you send me a sample?obelisk wrote:The Option/Read-write/Read/camera RAW
obelisk
Re: NEF too dark?
Here is a dark nef file
http://www.filedropper.com/dsc2356
Re: NEF too dark?
Option/View/Misc is on half or full size?
obelisk
Re: NEF too dark?
is 'embedded thumbnail'
what does that setting mean?
tried other settings, seems no change.
Re: NEF too dark?
It's the jpeg that you see, try 'half size', and change RAW settingsobelisk wrote:is 'embedded thumbnail'
obelisk
Re: NEF too dark?
thanks. This confuses me. I was seeing the jpeg, but the jpeg is also 100% size? I thought jpeg was only thumbnail size.
I have some Q about settings for RAW
Gamma is 2.2
what's the 'standard' setting for brightness?
what is 'high resolution'
Gamma is 2.2
