XnView 1.96
-> open an image
-> Image -> Add Text... -> enter something -> OK
-> now you have the Text attached to the mouse cursor to place it somewhere
-> don't click anywhere yet but instead zoom (mousewheel) the picture (to get the position more precicely) -> move the mouse
=> Do you see the issue? XnView "placed" the text to the position where you had the mouse before the zoom. Dropping the text onto the image via mouseclick then removes the previously incorrectly placed text. So that's ok. But it still needs to be fixed.
Thanks!
FIXED (1.96.1)
"Add Text" Problem (FIXED)
Re: "Add Text" Problem
Confirmed. Easy to reproduce with your good description.Dstruct wrote:=> Do you see the issue? XnView "placed" the text to the position where you had the mouse before the zoom. Dropping the text onto the image via mouseclick then removes the previously incorrectly placed text. So that's ok. But it still needs to be fixed.
