The folder tree do not update when a new folder is created within (or outside) Xnview MP and therefore making it unaccessible. Restart of xnview is needed to update the folder tree.
1. Select "New folder" from the edit menu in order to create a folder.
2a. If you have your filter set to hide your folders in the thumbnail pane then you don't have any way to rename or use this folder.
2b. If you have your filter set to show your folders in the thumbnail then you can rename it and use it but the treefolder is NOT updated.
PS.
Thanks for porting the excellent xnview to Linux.
v0.12 Linux (Ubuntu 8.10): Folder tree dont update
etrash2000
