[FIXED?] V012 Linux: CRITICAL Comment deletes image
etrash2000
Post by etrash2000 »
THIS IS A VERY CRITICAL BUG.
Description:
Images are DELETED when writing a comment to a single or multiple images.
1. Select one or more jpg images.
2. Select "Set comment" from the Edit menu.
3. Write a comment and press the "Write" or "Write all" button to commit the write.
WARNING: This action will delete your file.
4. Xnview do not indicate any error as the thumbnail pane is not update. An external filemanager will show that your files are deleted.
If I may recommend: Disable the comment function in new release 0.12b asap until a fix is done.
Ps. Thanks for porting xnview to Linux. I am using Ubuntu 8.10 and Debian 6.
Re: V012 Linux: CRITICAL Comment deletes image
Known issue
