Hello xnview users,
I am a little helpless! I have an old Corel Gallery cd with cliparts.
But the format bmf cannot be read by XnView. I get a report this is:
The format of the file " XYZ" cannot be determined.
The Xbmf.dll is available in the Plugin information. What could be the reason for this?
Perhaps somebody can help me.
Many thanks in advance.
I must correct me, the thumbnails are shown only with the XnView icon and file names.
The graphic itself I can copy and insert in another program.
BMF Format cannot be read
charly2008
charly2008
Re: BMF Format cannot be read
Dear Pierre,
I use Xnview now in Windows 7. I put the BMF-Plugins in the plugin folder but in the Tools Menu the plugin does not appear.
The problem still persists. Is there any solution for it? How can i send you a sample? I didn't find the posibility to attach a file.
Karlheinz
Karlheinz
No, BMF is not an Addon (Menu plugin). Is listed in Info>Supported formats
