IPTC data for multiple pictures
anke
Post by anke »
I've been using xnView for years and it's just a great program! But now I do have a problem and I hope you can help me. I would like to save iptc-data to my pictures, but I don't get along with that dialog :?
I sorted my pictures to xnView-categories and my idea was to choose a category, mark all pictures, use strg + i and define the iptc-category. That woks fine as long as the pictures belong to just one category. But if, in a later category, there is a picture that has already an iptc-category, this gets copied to all other pictures.
Or, to say it in easier words: Take the first two pictures in a folder and give them the category A (iptc) and then mark the first and the third picture and give them the cat. B. The result is that the fist and the third pic have category A and B now. But I want the first one to have A and B and the third one to have only B. Is that possible?
I tried all combinations in the writing options but I don't get it. Is that really not possible or am I just to blind to see?
Thanks a lot for your help :)
best regrds
anke
Re: IPTC data for multiple pictures
Try:
Select your pictures
IPTC dialog, clear all
Enter your category, and write all
It works?
anke
Post by anke »
I've only seen you answer today- thank you.
But that will not work because categories saved before will be lost. I want to keep them to the pictures that have them, but not copy it to other pictures while giving ALL pictures in the folder another category :?
anke wrote:I've only seen you answer today- thank you.
No, try on temporary files.
dam_ged
Post by dam_ged »
Hi Pierre,
I enjoy your program but I have exactly the same problem with keywords and categories in multiple IPTC editing.
Let's consider the photos A (a dog), B (a cat) and C (a duck).
1. I assign "dog" to A.
2. I go back another day and assign "animal" to A, B, C through multiple editing
3. The result is all the pictures get "animal" and "dog" !!!
How can I fix that?
And I don't get what you said about temporary files :?:
My version is 1.96.2
Thank you in advance!
