When starting a Video with the Quick Slideshow
When i start a quick slideshow with videos,
In a fixed size,
after its started, i cant no more move the slideshow square where i want in my deskopt...
Is there a way, to move the Slideshow while the Video is started ?
Move the SlideShow while Watching a Video
Re: Move the SlideShow while Watching a Video
You mean the "normal" slide show?
In slide show I can confirm. Moving the slide show window is not possible while video is playing.
OK thanks
Does its have a way to fix that with a plugin or something
you guys will do a update for that ?
