I've downloaded the webs and pngout plugin. Copied the contents to "C:\Program Files (x86)\XnView\PlugIns\" but I don't see the new functions anywhere in XnView.
"Info->Plug-Ins Information" only shows Xjp2.dll, the one that I've selected during install.
How do I install plugins?
Re: How do I install plugins?
• You must copy it in the …\XnView\AddOn\ sub-directory !
Notes :
1. It can be pretty long in using this add-on…
2. Personally, I never install XnView (or any other programme) in that location…
always in the root of a drive, i.e. simply : C:\XnView\*.*
lo
Thank You! It worked.
Good to read that your "problem" is solved, Waldo.
Topics "Addons/Plugins/..." and "Let's talk about Plug-Ins" might be still interesting.
