I have to write a script where at one point, I must convert a CCITT-Group4 TIFF file to a PDF, but there's a problem with the output file. Embedding this monochrome image within a PDF, Nconvert turns it into an image with a colordepth of 8... I use Nconvert version 5.30 and the following command:
nconvert.exe -binary nodither -keepcspace -colors 2 -out pdf -c 4 -o file.pdf file.tif
I also tried using no "-keepcspace" and "-colors" options, having no greater success. Using Acrobat 6 Pro to do the job, the embedded image keeps its original colordepth.
Could anyone help ?
Converting TIFF-G4 to PDF
Re: Converting TIFF-G4 to PDF
If you remove -colors 2?
benmmiv
Right, using the above command. I then decided to use GS, even if I have to rotate the image after (it always comes portrait oriented).
Thx anyway.
Benoît
Thx anyway.
Benoît
