Flickr geotags
Jaff
Flickr geotags
Post by Jaff »
This is quite simple. Please add 3 keywords (if GPS data is present in EXIF) to IPCT & update them also in XPM.
Also if GPS data is present only in IPCT/XPM (via geotags) you can create the minimum (lat & lon) GPS data in EXIF.
geo:lat=44.43408628
geo:lon=24.37181712
geotagged
This is where I am now :P (used as example)
see also: http://en.wikipedia.org/wiki/Geotagging ... ed_systems
marcoswat
Re: Flickr geotags
Post by marcoswat »
a bit specific isn't it?
maybe in a plugin, but not the main program :|
Jaff
Re: Flickr geotags
Post by Jaff »
marcoswat wrote:maybe in a plugin, but not the main program :|
and why not in the main? since IPCT, XPM and EXIF are handled by main program and not by a plugin.
Imi este indiferent ce cred ceilalti despre mine, caci oricum fiecare crede ce-i convine lui si nu ceea ce e real, doar ca mi-ar fi placut sa ma vada asa cum sint de fapt, nu asa cum poate le-ar placea lor sa creada. Ei au ales deja...
