false count of objects ?
goldenfingaz
Post by goldenfingaz »
Hi, i found something that could be a bug. They are 6 Objects, the "..." should not be a object right ?
Im using V1.96.
Re: false count of objects ?
:arrow: goldenfingaz
:) Hello !
• This was already discussed in the past, IIRC…
- From my own point of view, •• is a virtual “directory” for Windows, so it's reported as an object by the OS…
- I don't think it's worth a complicated correction to the objects count, Pierre has other fish to fry… :D
:mrgreen: KR
goldenfingaz
OK, thx for info. :p
Clo wrote:• This was already discussed in the past, IIRC…
YRC, Clo: Folder information in status bar
It's a minor issue, but still an issue. Perhaps the wording can be changed as suggested by Dreamer in the above mentioned topic.
obelisk
Post by obelisk »
maybe related, sometimes opening an image directly, pgdn to the end, it actually stops at the 2nd last image. If I press enter -> browser, then enter->viewer it will then pgdn once more to the last image.
:bugconfirmed: :bug: :bugfixed:
