Hey guys,
I tried to create multipage file and it did not work.
I have chosen two one-page PDF files, added them into the list, gave a new name for multipage file, chose PDF extention for it, clicked "Create", and... nothing happened!
What did I do wrong?
Thank you!
Lysyj
"Creating multipage file" option does not work
lysyj
Re: "Creating multipage file" option does not work
• Hm… Is GhostScript installed in your PC ? I assume it's needed to handle PDF…
- However, in such a case, you might get an error message telling that GhostScript is not found blah blah…
- Please, see the FAQ here, and search for GhostScript too.
lysyj
Thank you, Clo!
It seems you were right, but after the downloading that Ghostscript stuff I was not able to find any setup/installing file. Funny, huh?
Well, anyway, I already found another way which allows creating multipage PDF files pretty easy and without cumbersome Ghostscript downloading/installing. I will use XnView only for playing with pictures... Pity.
Regards,
Lysyj.
Regards,
Lysyj.
Clo wrote:lysyj
Hello ! Welcome aboard !
Kind regards,
ftp://ftp.wh2.tu-dresden.de/pub/mirrors ... 853w32.exelysyj wrote: It seems you were right, but after the downloading that Ghostscript stuff I was not able to find any setup/installing file. Funny, huh?
eL_PuSHeR
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
GeForce GTX 970 (Gigabyte)
8 GB DDR4 (2100)
Please have a look at FAQ How to display vector formats like PDF, AI,...? GhostScript!.
