Would it be simple to add an "automatically size the page" option to the Create Contact Sheet feature?
Basically if I select a whole bunch of images, I only really want to specify the size of the thumbnails and how many rows & columns to use. Having to do math myself to figure out the width/height of the page always throws me and I never really end-up with the right results. (Also, splitting the contact sheets into multiple pages isn't always ideal so having that as an option too would be great.)
Thanks again!
-volve
Autosized Contact Sheet
Re: Autosized Contact Sheet
So you would like to enter only width&height of thumbnail not page, right?
volve
Correct.
Thank you for responding!
Sim
I have a similar request, but it could be done in a way similar to the Windows Picture Viewer in Windows 7.
You choose the number of pictures per page, and Windows does everything for you, automatically adjust picture size to fill the page as most as possible, according to the printing paper you want to print to.
