When you set the capture to take the snapshot after a certain delay (tried with the defaul 5 sec), even if you uncheck the box saying to minimize XnView, the program gets minimized the same as soon as you start the capture by clicking OK.
Using a shortcut to start the capture (tried with the F9, F10) then if you uncheck the option to minimize XnView, the program correctly remains in maximized.
Delayed capture, xnview window always gets minimized
andrea.ippo
Re: Delayed capture, xnview window always gets minimized
Confirmed. I think that's a bug, XnView should only minimize if "Hide XnView" is checked.
