Converting images to .stx format
deve
Post by deve »
I am trying to use the xnviewer for converting but there is no extension like .stx to convert so I decide to use nconverter gui and typed
nconvert -i image.gif -o stx
but it says cant open file -o ??
marsh
Re: Converting images to .stx format
Post by marsh »
deve wrote:I am trying to use the xnviewer for converting but there is no extension like .stx to convert so I decide to use nconverter gui and typed
You want to read them or write them? I think you'll need to wait for writing ability, since nconvert shows this message:
Error: This output isn't possible (not yet implemented) (output.stx)
This topic explains how the viewer reads the rarer types: Does XnView support graphic format .xyz?
For nconvert usage: How to use nconvert
deve
Post by deve »
thanks but on list off supported file formats it says .stx file format also ??? for input and output!
I am doing something wrong I think :
I did type also convert jpeg to gif like : nconvert -i image.gif -o jpg and it still says
error cant read file -o ?
:arrow: deve
:) Hello !
…it says .stx file format also ??? for input and output!
• Nope ! In XnView (same supported formats), you can see that only reading is supported
on THIS ONLINE PAGE :
SBIG CCD camera ST-X | stx
:mrgreen: KR
deve
Post by deve »
Clo wrote::arrow: deve
:) Hello !
:mrgreen: KR
ya ya cool dont no where you get that but in the main page of xnview it says for read and write for that extension , anyway I have to find another tool for it understand thank you .
deve wrote:ya ya cool dont no where you get that but in the main page of xnview it says for read and write for that extension , anyway I have to find another tool for it understand thank you .
Same one the XnView page of supported formats: Read support for STX files, only. Where did you find the information that writing STX is supported by XnView?
