Is there a way to view .AI and .EPS files with Xnview?
I tried the open with option to open them with Ghostscript but it keeps saying I don't have it installed when in fact I do.
I really need a viewer for these file types.
.ai .EPS
marsh
Re: .ai .EPS
Maybe these forum links where ghostscript and registry are mentioned will be useful:crucify wrote:Is there a way to view .AI and .EPS files with Xnview?
A: GS problem
View image in AI. (Adobe Illustrator) format
XnView and Ghostscript
AFPL ghostscript not found on your system is annoying!
"AFPL ghostscript was not found on your system"
