Export to PNG
MaxSt
Export to PNG
Post by MaxSt »
It looks like "No filters" produces the same result as "All filters".
Should be different things.
ckv
Re: Export to PNG
Post by ckv »
PNG is a lossless format so you wont be seeing any image quality difference when changing the filter method, but the file size should be different. Those filters are used to... "to prepare the image data for optimum compression."
Read more about the filters:
http://www.w3.org/TR/PNG-Filters.html
