Saving Images
willgoss
Saving Images
Post by willgoss »
I am having trouble saving files after editing.....
For some reason save as loses the directory from which it was loaded....this makes me look through all my directories to find where it came from...or to simply save as a different file type.....
At least one program I use has save (same directory) which works well.....
marsh
Re: Saving Images
Post by marsh »
This is the option I leave unmarked:
Options>General>Operations tab>[ ]After 'Save as', change filename
willgoss
Re: Saving Images
Post by willgoss »
Thanks.....but I noticed with new version today.....save as was keeping the original directory......without that being checked....but I checked it and it still is working....oh well....
marsh
Re: Saving Images
Post by marsh »
willgoss wrote:Thanks.....but I noticed with new version today.....save as was keeping the original directory......without that being checked....but I checked it and it still is working....oh well....
Hmm... it must be the other one:
Options>General>File Operations tab>[x]For 'Save as', use same original pathname & format
If I use 'save as' to other directories, it returns to original each time with this checked.
willgoss
Re: Saving Images
Post by willgoss »
Yes that is the one I checked and unchecked.....and it seems to work either way....
I have struggled with some differences as I convert from using FastStone as browser and IrfanView for editing/running plugins.....Drag and Drop and paste into preview view are still areas to relearn......
Thanks for the Help.....
