gflAutoCrop
Martin Schmidt
gflAutoCrop
Post by Martin Schmidt »
If i use backgroundcolor 255, 255, 255, 0 gflAutoCrop will not work.
GFL_COLOR cropcolor;
cropcolor.Red = 255;
cropcolor.Green = 255;
cropcolor.Blue = 255;
cropcolor.Alpha = 0;
GFL_ERROR result = gflAutoCrop(m_Bitmap, NULL, cropcolor, 0);
gflAutoCrop returned no error.
XnView crop the bitmap korrekt!
If i use backgroundcolor 0, 0, 0, 0 in my bitmap, gflAutoCrop work.
Re: gflAutoCrop
Martin Schmidt wrote:If i use backgroundcolor 255, 255, 255, 0 gflAutoCrop will not work.
Could you show your picture used for autocrop?
Martin Schmidt
I do not show the picture with my tool. The Result of gflLoadBitmap was successfully.
I could need a new feature in gflAutoCrop. I need the position of the cropped picture in the source picture. Now i must compute separately this parameter.
I would be very grateful, if you could help me.
Martin Schmidt wrote:I do not show the picture with my tool. The Result of gflLoadBitmap was successfully.
No, i means show me the original picture?
Martin Schmidt
Thanx for bugfix.
tailormade
Still in 2.40?
Post by tailormade »
I am using V2.40 and I am having the same problem. Did this fix not make it into 2.40?
Re: Still in 2.40?
tailormade wrote:I am using V2.40 and I am having the same problem. Did this fix not make it into 2.40?
On which bitmap did you use this function?
