Ratings?
marsh
Re: Ratings?
Options>Icon Info>[x]Use database to store file informationSpeedDevil wrote:When browsing pictures, when I right click on an image there is a menu which says "Rating & Colour Label" - but the items in the submenu are all disabled - how do i enable them?
SpeedDevil
Re: Ratings?
AH, you need to enable the database for that.marsh wrote:Options>Icon Info>[x]Use database to store file informationSpeedDevil wrote:When browsing pictures, when I right click on an image there is a menu which says "Rating & Colour Label" - but the items in the submenu are all disabled - how do i enable them?
But why don't you need to enable the database to store the categories then?
(not the IPTC categories, the ones in the tree view)
SpeedDevil
Re: Ratings?
Ok, to answer my own question:
After looking into it, it seems the program uses a second database for that - one which you can't disable.
