SKP files unknown when they come from Macintosh
Questions, suggestions, and answers for XnView on all Un*x platforms (Linux, HP-UX, AIX, ...)
Wouter Hagens
Post by Wouter Hagens »
I posted this question in another XnView newsgroup, but was suggested to put it in this one, so I do.
In the usersgroup of SketchUp I was made aware about the possibilities to use XnView for viewing SketchUp files. So I immediately started to look at XnView for Macintosh.
The problem I have is that files that I have taken from internet and are created using a PC are visible as "Autodesk SketchUp component (interlaced)".
When I load that file in SketchUp (latest version for Mac) and "save as" it is of an unknown type just as all the skp files created by myself on Mac.
My question is: how to solve the problem?
Regards,
Wouter
Re: SKP files unknown when they come from Macintosh
Wouter Hagens wrote:I posted this question in another XnView newsgroup, but was suggested to put it in this one, so I do.
Your files are visible by XnView?
Wouter Hagens
xnview wrote:
Wouter Hagens wrote:.....The problem I have is that files that I have taken from internet and are created using a PC are visible as "Autodesk SketchUp component (interlaced)".
Yes they are visible as file, but clicking gives: don't know how to read.
I don't know how to attach an image (partial screenshot) to a message in the newsgroup to show it.
If you want I can send you both skp files.
Wouter
Yes, please.
Wouter Hagens
xnview wrote: Yes, please.
I have sent the files to your address <!-- removed //-->
skpfiles.jpg is a partial screemdump,
powerbook.skp is the PC file of SketchUp
powerbook2.skp is the Mac file of SketchUp
I have also tried to save without the resourcefork and without the custom icon (option in Sketchup when saving the file); see customicon.jpg, but that did not make any difference.
Regards and thanks,
Wouter
Wouter Hagens
Wouter Hagens wrote: I have sent the files to your address <!-- removed //-->
Xnview/Pierre, did you receive the files?
No, please use [email protected] (remove -nospam)
Wouter Hagens
xnview wrote: No, please use [email protected] (remove -nospam)
I have done it with the text:
"I have now used smaller files. The file skpfile2.jpg is a partial screendump to show that file linus-1.skp is recognized as Autodesk SketchUp component (Interlaced) and linus-1mac.skp is of the type Unknown.
linus-1mac.skp has been created by loading linus-1.skp in SketchUp and immediately after that save-as linus-1mac.skp."
I hope that you have received the files now.
Best regards,
Wouter
Wouter Hagens
Wouter Hagens wrote: I have done it with the text:
Best regards,
Wouter
Did you receive the files and when can I expect an answer?
Thanks,
Wouter
Best regards,
Wouter
Yes, i have received it but currently i'm very busy so i'll reply asap
