Change information displayed in XnView's "title" bar
andrea.ippo
Post by andrea.ippo »
I don't know if "title" bar is the correct name for it, what I mean is the stripe where the application name is showed and the minimize, restore and close buttons are located.
Actually, the only info displayed by XnView in view mode is the filename + extension between '[' and ']'
How can I prepend the full path to the filename?
marsh
Re: Change information displayed in XnView's "title" bar
Post by marsh »
andrea.ippo wrote:I don't know if "title" bar is the correct name for it, what I mean is the stripe where the application name is showed and the minimize, restore and close buttons are located.
I don't think you can, but its a good suggestion for those "save as" options which change the directory you're using.
:arrow: andrea.ippo
:) Hello !
• This was discussed (again) recently in THAT THREAD… Despite the user's support and a noisy “BUMP” link :P we got only the Artic Silence from Pierre… :(
:mrgreen: KR
Clo wrote: • This was discussed (again) recently in THAT THREAD… Despite the user's support and a noisy “BUMP” link :P we got only the Artic Silence from Pierre… :(
Even if i don't reply, i read it
andrea.ippo
Where do we continue talking about this?
Here or http://newsgroup.xnview.com/viewtopic.php?f=34&t=17391?
The title of this topic is more general, I'd continue here since I'd like the possibility to customize the info displayed beyond the simple full path
What do you think?
And what about my suggestion:
What about some expression using image related variables, such as path, filename, size, bit depth, etc ?
Bye
andrea.ippo wrote:Where do we continue talking about this?
What do you think?
Yes, a good idea like info
