Some EXIF reading problem.
vorob
Post by vorob »
Sorry for my english, i'm russian.
I've got canon ixus 65, it write all photo data into jpeg file, for example:
Camera Manufacturer              : Canon
Camera Model                     : Canon DIGITAL IXUS 65
Orientation                      : top-left (1)
X Resolution                     : 180
Y Resolution                     : 180
Resolution unit                  : Inch
Date modified                    : 2008:07:19 12:02:27
YCbCr Positioning                : centered (1)
Exposure time [s]                : 1/500
F-Number                         : 2.8
EXIF version                     : 02.20
Date taken                       : 2008:07:19 12:02:27
Date digitized                   : 2008:07:19 12:02:27
Components configuration         : YCbCr
Compressed bits per pixel        : 5
Shutter speed [s]                : 1/501
Aperture                         : F2.8
Exposure bias value              : 0
Max aperture                     : F2.8
Metering mode                    : Multi-segment (5)
Flash                            : No flash
Focal length [mm]                : 5.8
FlashPix Version                 : 01.00
Colour space                     : sRGB
EXIF image width                 : 2816
EXIF image length                : 2112
Interoperability offset          : 2824
Focal plane X-Resolution         : 112640/9
Focal plane Y-Resolution         : 2112000/169
Focal plane res. unit            : Inch (2)
Sensing method                   : One-chip color area sensor (2)
File source                      : DSC
Custom rendered                  : Normal process (0)
Exposure mode                    : Auto (0)
White balance                    : Auto (0)
Digital zoom                     : 1/1
Scene capture type               : Standard (0)
IOP index                        : R98
IOP version                      : 0100
IOP width                        : 2816
IOP height                       : 2112
Macro                            : Normal
Selftimer                        : Off
Compression setting              : Super fine
Flash mode                       : Not fired
Drive mode                       : Continuous
Focus Mode                       : Single
Image size                       : Large
Easy shooting                    : Manual
Contrast                         : Normal
Saturation                       : Normal
Sharpness                        : 0
ISO value                        : 80
Metering mode                    : Evaluative
Focus type                       : Auto
AF point                         : Unknown
Exposure mode                    : Easy shooting
Lens Type                        : 65535
Long focal                       : 17400
Short focal                      : 5800
Focal units / mm                 : 1000
Max aperture                     : 95
Min aperture                     : 159
Sequence number                  : 8
Image number                     : 101-1568
Owner name                       :
LensID                           : 5800 17400 3
Compression                      : 6
X Resolution                     : 180
Y Resolution                     : 180
Thumbnail offset                 : 5108
Thumbnail length                 : 4230
So i asked to show me some things onscreen:
<Date Taken [Y-m-d_H-M-S]>
<Width>x<Height>
<ISO Value>
<Exposure Time>
But i see only date and resolution. No ISO and exposure. But i can read by myself this data from exif menu. Why? For my previous photocamera i can see onscreeen all this data.
Re: Some EXIF reading problem.
For ISO value, it's normal, this field is in Makernotes (not supported in info)
But exposure time should be showed...
vorob
Post by vorob »
Well, i don't see anything normal here. For my samung i can see iso value, and for my canon i can't. Both values are in exif info. There is no logic.
vorob wrote:Well, i don't see anything normal here. For my samung i can see iso value, and for my canon i can't. Both values are in exif info. There is no logic.
Info doesn't support Makernotes
vorob
Post by vorob »
Well, what is it, Makernotes?
vorob wrote:Well, what is it, Makernotes?
With EXIF you have standard info (camera, image, thumbnails, gps), and closed info (makernotes)
