Win32 and registry
MajorDad
Win32 and registry
Post by MajorDad »
Hi all
In registry i have do a new key in HKEY_CLASSES_ROOT\*\shell\Convert\command
I input following line as sample as REG_SZ
D:\tmp\nconvert -out png "%1"
Its like D:\tmp\nconvert -out png test.jpg in DOS
Now i klick on a picture test.jpg > context menue > Convert ..
The picture i selected is not converted to png O_o
Only the 'open with' dialog appear
I try the same with %%1 like the usage.txt say
Use NConvert not the %1 for the first parameter as the filename i selected ?
Thanks
MajorDad
*edit* haha .. no answer is a answere .. thx -_-
