Version: 1.96.1
When using the "Find similar files..." and using the "Move reference+selected file(s)" option only one of the selected files is moved even though all are indeed selected/highlighted. I am using the similar picture content option and haven't checked the others.
BTW: I would really like to be able to export the list - nconvert perhaps.
Daz
Find Similar files
eL_PuSHeR
Re: Find Similar files
And how can you select the other one from the pair when comparing images by content?. Interface is awful.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
GeForce GTX 970 (Gigabyte)
8 GB DDR4 (2100)
• Basic : Hold Ctrl + L-Click ?
eL_PuSHeR
I mean selecting the Reference image or swapping reference <> dupe
Intel i7 5960X
8 GB DDR4 (2100)
8 GB DDR4 (2100)
Dreamer
