Hi!
I noticed a problem with Animated GIFs seeming to have inverted or altered color when put in a Slideshow (CTRL+L) using certain settings. The settings that bring it on seem to be the combination of Stretch small pictures and Use high quality in More options.
Here is an example animated GIF I used in version 1.96:
http://izjuag.bay.livefilestore.com/y1p ... NIMATE.gif
Thanks!
Incorrect Color for Animated GIFs in Slideshow
pixelperfecto
Re: Incorrect Color for Animated GIFs in Slideshow
Ok, i'll check
pixelperfecto
Thanks for the reply!xnview wrote:Ok, i'll check
So what did you find? Is it a bug after all or simply a problem file?
