Thumbnails with wrong size
When displaying thumbnails, sometimes the thumbnails of images with embedded thumbnails are not displayed properly in size:
As you can see in the image above, the four thumbnails at the top have a wrong size. When using "Rebuild thumbnails" everything is o.k.. Thumbnail size chosen is 92x69 pixels. Looks as if there is a problem with displaying embedded thumbnails.
A minor display problem, still annoying...
Re: Thumbnails with wrong size
Thanks for the links, XnTriq. Even admins should use the forum search, first. ;-)
I've deleted the thumbnail cache completely and will post if the problem still occurs.
