recursive
mfeske
recursive
Post by mfeske »
is therie a switch in nconvert to works rekursive and than make the same folder in the tarket folder?
example:
pictures from c:\input an c:\input\01 to c:\output an (make self) c:\output\o1?
Greetings
Michael
Re: recursive
no :?
mfeske
Re: recursive
Post by mfeske »
both no :-(
or only the directory problem no?
but it´s a nice tool ;-)
Re: recursive
i don't understand the problem for target folder?
mfeske
Re: recursive
Post by mfeske »
Hello Pierre,
my problem is, I will work with the following files as source, for example:
c:\eingang\test.jpg and c:\eingang\test\test.jpg
if the target folder is the same one is overwriting the other.
if it possible to write the path in the target folder theire isn´t a problem.
for example
c:\ausgang\test.jpg and c:\ausgang\test\test.jpg
greetings
micha
Re: recursive
mfeske wrote: if it possible to write the path in the target folder theire isn´t a problem.
for example
Oh ok, like 'keep folder structure' in XnView? So no option...
mfeske
Re: recursive
Post by mfeske »
then of course it is a pity :-(
Gruß
Micha
hjklzxcva
Re: recursive
Post by hjklzxcva »
hi
You can follow this sample
FOR /D /R %%a IN (*) DO nconvert -jpegtrans exif -out jpeg %%~sa\*.jpg
It's like recursive function
mfeske
Re: recursive
Post by mfeske »
hjklzxcva wrote:hi
Hello hjklzxcva,
thanks for your answer, can you help me and explain, how does it works?
Greetings
Michael
mfeske
Re: recursive
Post by mfeske »
Hello I have make some changes in the batch for my special thinks but it works not :-( only the file in the first folder is convertet and copying to the correct position :-(
h:\vetmed_converter\script\exe\nconvert -npcd 2 -size 256x256+0 -ctype grey -corder inter -out jpeg -o H:\04_target_m\ch_%%_m.jpg -dpi 300 -ratio -rtype lanczos -rflag orient -resize 500 0 -wmfile "h:\vetmed_converter\logo\in_use\picture\ch_vetsuisse_m.tif" -wmpos -10 -10 -wmflag bottom-right -wmopacity 70 h:\ch\*.jpg
FOR /D /R %%a IN (*) DO h:\vetmed_converter\script\exe\nconvert -npcd 2 -size 256x256+0 -ctype grey -corder inter -out jpeg -o %%~sa\ch_%%_m.jpg -dpi 300 -ratio -rtype lanczos -rflag orient -resize 500 0 -wmfile "h:\vetmed_converter\logo\in_use\picture\ch_vetsuisse_m.tif" -wmpos -10 -10 -wmflag bottom-right -wmopacity 70 h:\ch\*.jpg
pause
exit
Can you help me?
Greetings
Micha
