Fellow Forum Members,
I have been using IrfanView for years, but now it has failed me. I need to perform 20 PDF screen captures and each of the PDF screen captures need to be saved to a unique screen capture directory. The link below shows a screen shot.
http://en.irfanview-forum.de/vb/showthread.php?t=4420
Does XnView support multiple save to destination directories? Any info will be greatly appreciated. Thanks.
Multiple Screen Captures Directories Supported?
eL_PuSHeR
Re: Multiple Screen Captures Directories Supported?
Just my suggestion:
Get PDF-Xchange Viewer and use Export > Export to image. You can use macros to name the resulting files and even create a multipage TIFF. Anyway, after extracting pages, do with them whatever you like.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
GeForce GTX 970 (Gigabyte)
8 GB DDR4 (2100)
