Wrong rating colors
delta
Wrong rating colors
I'm probably the n-th guy (where n >> 0) pointing this out (sorry): Did anyone notice that the rating colors in the tree pane and the overlays in the thumbnail pane are not the same? In the tree pane it's, from 1 to 5 purple-red-orange-yellow-green whereas the overlays go red-orange-green-blue-purple. That's probably not intentional, is it?
Re: Wrong colors
I have not that, which skin do you use?
delta
Re: Wrong colors
Oh, right, my mistake. I thought skins would not affect those rating icons because changing the skin changes the buttons right away but the rating icon after restarting xnview. So I was like: "Hm, strange, those icons are wrong. Maybe it's in the skin? *switch* Nope, that changes just the buttons. *switchback*"
It's a mistake in the Tango skin, "Tango by Vlatko ver 2".
