Tagging in multiple folders is broken
Dreamer
Post by Dreamer »
- tag 2 files in any folder
- tag another 2 files in another folder
- press Ctrl+U for Batch processing (or F2 for Batch rename)
- click "tagged files" button
= only the tagged files from the other (last) folder are in the file list :bug:
XnView 1.96.1, Windows Vista SP1.
Dreamer
Re: Tagging in multiple folders is broken
ok, i'll check
It's not really a bug. I think that using tagged files from current folder is better than all tagged files.
Dreamer
Post by Dreamer »
I don't think so, then it's the same as "select". Tagging the files from more folders is the main advantage of the tag feature. :?
For this purpose there is a dialog "use selected / tagged files" and another option "tagged file list must be cleared / after folder change".
Currently there is no way to create slide show, or convert images from 2 (and more) folders.
Dreamer
Dreamer wrote:I don't think so, then it's the same as "select". Tagging the files from more folders is the main advantage of the tag feature. :?
But i have not changed this behavior, XnView has always worked like that :-)
"Show all tagged files"
Dreamer
Post by Dreamer »
Hmm... OK then, you're right.
Dreamer
