When we use the "Add Text" feature under the "Transformations" tab (XnView 1.96), while converting an image, the default setting of the text is set to Courier, Regular, 10. Is there any way to change this setting to a different one? It's really frustrating to do this again and again for every image that I have to convert, as the details that I need to add is different in every image.
Thanks,
-Jason.
Default settings for Text
Re: Default settings for Text
You can save a default script, currently settings are not kept
