unable to open SUN raster file
rra
Post by rra »
I have found a bug in XNVIEW,
not allowing me to open & display a black/white SUN raster file,
possibly due to the fact that is has strange dimensions:
its width is 22368 yet its heigth is only 6 pixels.
Paint Shop Pro does show the image,
so I think it is some kind of limitation of XNVIEW (1.96.1)
René
Re: unable to open SUN raster file
could you send me the sample?
rra
Post by rra »
never known how to send data to you,
this way should work also ...
http://members.home.nl/ramekers/G30464.ras
Xnview 1.96 says: Sun Raster : Bad picture's size !
René
eL_PuSHeR
Post by eL_PuSHeR »
I get the same behaviour as OP. Irfanview displays it properly.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
GeForce GTX 970 (Gigabyte)
right, i'll fix it
