add ".apng" support
roytam1
add ".apng" support
Post by roytam1 »
".apng" files won't show thumbnail in 1.96.1. Hope it will be added in the future.
Re: add ".apng" support
:arrow: roytam1
:) Hello !
• I've thumb nails and previews as expected here in 1.96.1 for A-PNGs, no problem.
- Under Win XP-Pro SP1 - 32-bit. Please, check your settings…
- Are the A-PNGs you are talking of displayed in View ? Some ones made by some softs can cause problems,
this was discussed a lot here a while ago…
:mrgreen: KR
ouistiti
Post by ouistiti »
I confirm that the thumb nails are shown for A-png here too in 1.96.1
Friendly
Paul
1,77245385090552...
roytam1
Post by roytam1 »
Clo wrote::arrow: roytam1
:) Hello !
:mrgreen: KR
I mean the ".apng" file extension.
I know XnView supports APNG with ".png" file extension, but not with ".apng" file extension.
:arrow: roytam1
:) Hello !
…I know XnView supports APNG with ".png" file extension, but not with ".apng" file extension…
• It does too, just add APNG in the Include field in Options >> Filelist, ensure you that "Recognize only by extension" is disabled.
- I tested on this moment, that works…
:mrgreen: KR
roytam1
Post by roytam1 »
:) Hello !
:mrgreen: KR
Yes XnView will work when Recognize only by extension is disabled.
But IMHO it is not the best solution for users.
