ICO Multi-page Files?
Mike Truly
Post by Mike Truly »
I have some ICO files which are multi-pages (they have 2 pages). If I go and adust the Hue of the icon and then try to save it, I get a warning about it being multi-page and it will only save the current page. Is there any way to save both pages back into the icon?
Thanks!
Sincerely,
Mike Truly
Truly Media
http://www.trulymedia.com
Re: ICO Multi-page Files?
:arrow: Mike Truly
:) Hello Mike !
• That isn't possible easily as one go… You might extract the two pages in a temp. dir., change the page you want then rebuild the multi-page ICO overwriting the original… :|
- You can perform this using i.e. Greenfish Icon Editor Pro, gratis and no install… ;)
- With that tool, you may change a single page and save the whole file directly :D
:mrgreen: KR
Mike Truly
Claude,
Thanks very much for this info. I have lots of icons (multi-page) icons which contain the color blue and was hoping to batch-adjust the hue on all of them so that all the blue was changed to another color (such as purple) at one time. I thought XNView would be perfect for something like this but it will not save multi-page ICOs. Photoshop will not even open them (which is absurd considering how much I have paid for that software). Will look into that software link.
Thanks!
Sincerely,
Mike Truly
Truly Media
Mike Truly
Claude,
Thanks very much for the link to that icon editing software... it works great. I do wish it had the capability to batch adjust images (it can batch convert but not batch adjust like XNView does) but I did them one-by-one and it works great.
Thanks again!
Sincerely,
Mike Truly
Truly Media
:arrow: Mike Truly
:) Hi Mike !
• Glad to hear that you could solve the issue with GFIE !
- Yes, I forgot to mention that it doesn't support all operations in a batch, this indeed could be a “plus”…
- Unfortunately, currently the development is not stopped, but “on idle”, so we miss still a few features like this one (also the support of 32 BPP BMP, planned though).
:mrgreen: KR
