Open with... - Remove Program
arm.in
Post by arm.in »
Hi Pierre,
I like using XnView as an image browser. For editing, I right-click the concerning image and "Open with..." my favorite image processing software. Over time, several versions of one software are released, for example Corel XI, X2, X3 and Paint Shop Pro X, X2, ...
Now it is easy to "Add Program..." to the "Open with..." list. To remove just one of e.g. five tools, you have to "Remove All" and add all others that you like again. Would it be possible to modify the dialog and offer a point to "Remove" one entry or "Edit" the list of entries? :wink:
Best regards,
Armin
Re: Open with... - Remove Program
arm.in wrote:Would it be possible to modify the dialog and offer a point to "Remove" one entry or "Edit" the list of entries? :wink:
Ok, currently you can edit the xnview.ini
arm.in
Post by arm.in »
Yes, you are right :D
Best regards,
Armin
