Display Color Information config not saved
janoskist
Post by janoskist »
Hello
if started Xnview View/Display Color Information checkbox is unchecked.(its ok.:)
After checkin this box exit xnview.
Next time started xnview the Display Color Information checkbox remain unchecked.
Possible solution for allways check on this box?
Thanks!
marsh
Re: Display Color Information config not saved
Post by marsh »
From topic, UI-less Settings:
ColorInfo:
Changes the behavior of the colour information tool feature.
0. Show only for the currently viewed image.
1. Show also for the previous¦next file to view.
2. Show between sessions.
Value: Integer, default value is 0
janoskist
Post by janoskist »
Thx.:)
