"Add Text" doesn't support "&" character properly (FIXED)
Dstruct
Post by Dstruct »
XnView 1.96.1
-> Add Text
-> OK
=> No text can be pasted
-> Add Text
-> OK
=> Single & can be pasted
-> Add Text
1 & 2
-> OK
=> 1 _2 can be pasted
FIXED (2.36)
Dstruct
Re: "Add Text" doesn't support "&" character properly
Post by Dstruct »
Similar problem with | character.
-> Add Text
-> OK
=> | can be pasted onto image
-> Add Text
=> Now the dialog is showing a strange square character:
FIXED (2.36)
Dstruct
Post by Dstruct »
No one?
rra
Post by rra »
The only "bug" I found with the "&" char
is that one has to type it twice to the text-string to get it displayed once.
No problems with the "|" char for XnView 1.96.2 !!
René
Dstruct
Post by Dstruct »
Im on german Windows XP SP3 with german keyboard layout. Maybe that's why?
Dstruct wrote:Im on german Windows XP SP3 with german keyboard layout. Maybe that's why?
There's nothing wrong with your keyboard, Dstruct. This is clearly a bug in XnView.
Dstruct
Post by Dstruct »
Not fixed in 1.96.5 ...
Dstruct
Post by Dstruct »
Dstruct wrote:Similar problem with | character.
-> Add Text
-> OK
-> Add Text
This problem still is exists in 1.97! Only the "&" problem is fixed.
Dstruct
Post by Dstruct »
Same in 1.97.1 ...
Dstruct wrote:Same in 1.97.1 ...
Yes not in the changelog :-) (not easy to fix, can be a problem with old .ini)
Dstruct
Post by Dstruct »
xnview wrote:(not easy to fix, can be a problem with old .ini)
What do you mean with that?
Here another weird issue:
Try to add <<< as text onto an image. Result: Just two arrows << get pasted onto the image!?
Dstruct wrote: Try to add <<< as text onto an image. Result: Just two arrows << get pasted onto the image!?
Yes normal, <..> is used for placeholder
Dstruct
Post by Dstruct »
Placeholder for what?
marsh
Post by marsh »
< and > pass on commands listed with the "Insert" button, like <Filename>
