Couple of suggestions
ThatEvilGuy
Post by ThatEvilGuy »
Hey,
I'd like to suggest couple of features that IMO will improve the this already great program.
1. It would be really great to have the ability to move pictures around in browser, currently you can only sort them but to place pictures individually and sort them yourself would be great.
2. Mouse 4, Mouse 5 support Back/Forward with a 5 mouse button. It would be great if this program supported that and gave you ability to configure those two buttons with custom commands.
3. I mentioned this already but still, Fit width for LARGE pictures only, currently what program does is that if the image is small is stretches it across the width of the screen, would be great if it only reduced the size of the large images and fit them to the width.
I hope you will consider some of these features, Thanks!
